Group: DynoMotion Message: 9422 From: rjreese29@ymail.com Date: 4/20/2014
Subject: Encoder position read
Hi, I am just getting into this and working on hooking up a single ended encoder to pin 42 and 43 on my kflop with no additional dynomotion hardware. There is no motor wired to it yet to move anything, but it is programmed and does jog digitally for channel 3 (4th axis) It is reading the io state changes in digital io screen, but is not moving in 'position' on the axis screen. Just moving the encoder by hand. The input channel is registered for encoder as the input and the channels point to io bits 42&43. What else am I missing here? Second question- I am trying to wrap my head around channels and io pin assignments,, why does the kmotion software not allow drop down selection or manual input of io bits for both channels when set to "encoders" as the input? And why does it only allow selection of 0-14 in the non-greyed out box? Thanks, Rob
Group: DynoMotion Message: 9423 From: Tom Kerekes Date: 4/20/2014
Subject: Re: Encoder position read
You seem to be confusing Pin Numbers with IO numbers as well as Pin Numbers and Device Channels.
Please read this Thread on cnczone to see if it helps:
Group: DynoMotion Message: 9424 From: Rjreese29 Date: 4/21/2014
Thanks Tom. I will read that post (more than once).
Btw, I got it working on channel 7 just minutes after I hit send on that post.
Rob
